7 members (jay d, Bill Hanlon, RaNfLaS, GMCJammer51, DadsFirstPickup, Tyler Watts, Steelonsteel),
94
Mod | | | Forums66 Topics128,048 Posts1,055,663 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 4 New Guy | | New Guy Joined: Oct 2007 Posts: 4 | any of you '66 knowledged guys know if the dics brakes from a '67-'72 will fit a '66 truck...1/2 ton? need to change the spindals too? what is involved. saw on trucks on tv year ago or so they did this, but really was not interested in it at the time. wanting to know what all is involved. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | There has been some info on this before. You might find it in a search. You will need to change the spindles but there is more like the lower control arm or ball joint. Its a common swap. I'm sure someone who has done it will chime in. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Nov 2008 Posts: 355 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 355 | would be just as cheap and time saving to just get a disk brake conversion from one of the many companies offering them for around 100.00 and then all you would have to supply is the rotors and calipers from a mid 70s gm car
1937 1/2 ton
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Swapping balljoints and I beleive the outer tie rods will allow for use of the '73-'87 spindles, or the entire crossmember from the '73-'87 could be used (4 holes need to be drilled) and gain power steering at the same time. Doing this also allows you to use brakes designed for truck use. The rear axles can be swapped for later 12 bolt axles, the need to be shortened (3/4", I think) to work in the existing axle housing, plus use the later drums to change the rear to 5 lug (5x5" bolt pattern).
Bill Burmeister | | | | | Joined: Dec 2001 Posts: 141 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2001 Posts: 141 | It is possible to swap the crossmembers from '71-87. The most preferrable choice is the '71-72, as the rear end is swappable as well, giving you 5 lugs all around. After '72, the rear went to leaf springs and all the mounting brackets change.
I am currently writing a tech tip for this very thing. I swapped the front and rear of a '75 onto my '64 frame. Sorry it's a little late, but hope it helps. | | |
