8 members (JW51, Woodcmiami, Gdads51, dt235sd, MickeyP, HandyAndy, k2handyman, 1 invisible), 58 guests, and 1 robot.
Topics128,049
Posts1,055,699
#523757 04/02/2009 5:31 AM
any of you '66 knowledged guys know if the dics brakes from a '67-'72 will fit a '66 truck...1/2 ton? need to change the spindals too? what is involved.
saw on trucks on tv year ago or so they did this, but really was not interested in it at the time.
wanting to know what all is involved.
37gonnatubit #523998 04/02/2009 11:00 PM
Riding in the Passing Lane
There has been some info on this before. You might find it in a search. You will need to change the spindles but there is more like the lower control arm or ball joint. Its a common swap. I'm sure someone who has done it will chime in.
1972 Chevy c10 Cheyenne Super
would be just as cheap and time saving to just get a disk brake conversion from one of the many companies offering them for around 100.00 and then all you would have to supply is the rotors and calipers from a mid 70s gm car
1937 1/2 ton
Daniel Bland #524089 04/03/2009 3:00 AM
Swapping balljoints and I beleive the outer tie rods will allow for use of the '73-'87 spindles, or the entire crossmember from the '73-'87 could be used (4 holes need to be drilled) and gain power steering at the same time. Doing this also allows you to use brakes designed for truck use. The rear axles can be swapped for later 12 bolt axles, the need to be shortened (3/4", I think) to work in the existing axle housing, plus use the later drums to change the rear to 5 lug (5x5" bolt pattern).
Bill Burmeister
LONGBOX55 #539558 05/20/2009 8:21 PM
It is possible to swap the crossmembers from '71-87. The most preferrable choice is the '71-72, as the rear end is swappable as well, giving you 5 lugs all around. After '72, the rear went to leaf springs and all the mounting brackets change.
I am currently writing a tech tip for this very thing. I swapped the front and rear of a '75 onto my '64 frame. Sorry it's a little late, but hope it helps.
Mike from Alabama
My truck on Stovebolt
My website
Why do we drive on a parkway, and park on a driveway?
