0 members (),
35
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53930 12/24/2005 6:04 PM | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | I installed an overdrive transmission in my 62 1/2 ton truck last year-worked fine for a while but now jumps out of third gear going up a slight hill while in OD. Adjusted shifting arms, tried heavier grear lube (140 wt), all to no avail. Now just attach a bunji cord ! Any suggestions? All gears are quiet and mileage is over 20 mpg with my 235 six so would like to salvage the trans without having to pull it. This a three on a tree setup with a switch used to engage OD. Merry Christmas from Texas!
Green Machine
#53931 12/24/2005 8:35 PM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | You'll need to replace the gear, baulk ring and syncro-sleeve to fix it properly. Maybe even the shift fork. Probably should do the bearings too while it's out and apart, Scott | | |
#53932 12/24/2005 10:38 PM | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | You can pull the cover & check the shift fork & detent spring. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | |
#53933 12/28/2005 12:35 AM | Joined: Feb 2001 Posts: 81 Shop Shark | | Shop Shark Joined: Feb 2001 Posts: 81 | Thanks for the replies! I am trying to keep from pulling the trans again. Wrenchbender please expand on your suggestion. Assume that I can pull the cover with the trans in truck. What do I look for? Also if I have another cover from a trans can't I just swap them out? The trans in truck is a Munsie and I have a cover from a Saganaw-will they interchange? Thanks for any help or ideas.
Green Machine
#53934 12/29/2005 1:37 AM | Joined: May 2005 Posts: 27 Junior Member | | Junior Member Joined: May 2005 Posts: 27 | I have a 62 1/2 ton truck as well and am planning a tranny swap to a 3spd OD from a 59 Bel Air. Unfortunately I don't have any of the kick down stuff to engage the electrical solenoid. I can fab something if I knew what it was. What kind of setup kicks it into OD? I've thought about some vacuum switches from an AC unit. Thanks.
Priorities make dreams happen.
#53935 12/29/2005 3:48 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Stephan - the kickdown sw [on the carb] is actually to take it OUT of overdrive when you boot it - all you need is a manual switch to engage the OD when you want it, disengage when you don't - best to have an indicator light to show when it's on so you don't forget for a non-original electrical setup, there\'s some wiring info here Bill | | |
