3 members (Otto Skorzeny, jay d, SmalltownTRKGuy), 112 guests, and 1 robot.
Topics128,049
Posts1,055,634
PJS
Offline
Apprentice
Apprentice
My truck has the wrong knobs on the choke and throttle cables.(it's a 52 half ton) I have a pair of correct original knobs on broken cables and I would like to swap them for the knobs in the truck. Is there a way to get the darn things off the metal shaft on the end of the cable without destroying the knobs? thanks
pat
1952 Chevy 1/2-Ton
No, they are cast onto the cables, you need to replace the whole cable.
DG
Denny G
Sandwich, IL
They give a method of doing this in the "How to restore your Chevrolet Pickup" book but personally I wouldn't spend my time doing it. If I remember correctly they cut the old cable off, drilled out the knob and siver soldered it onto the new cable.
1951 1 Ton Completed
For my 54's cables I held the stem that the knob attaches to and held it a bench vise, then I heated the stem with a propane torch just enough to where I was able to pull the knob off the the stem. Then i used 5 minute epoxy to attach the old knob to the new cable.
I found a throttle cable/knob at a swap meet but the cable was too short. I cut it off and put the shaft/knob in a lathe and drilled a hole in the end. The local piano rebuilding shop miked my original wire and gave me a piece of piano wire the same diameter which I brazed onto the shaft/knob. Wire free, knob/shaft one dollar, brazing fifty cents. End results? Priceless! That was 10 years ago and it is still intact.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
