3 members (MickeyP, Joe H, Jon G),
121
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,050 Posts1,055,646 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2009 Posts: 26 Apprentice | | Apprentice Joined: May 2009 Posts: 26 | My truck has the wrong knobs on the choke and throttle cables.(it's a 52 half ton) I have a pair of correct original knobs on broken cables and I would like to swap them for the knobs in the truck. Is there a way to get the darn things off the metal shaft on the end of the cable without destroying the knobs? thanks
pat | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No, they are cast onto the cables, you need to replace the whole cable. DG
Denny G Sandwich, IL
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | They give a method of doing this in the "How to restore your Chevrolet Pickup" book but personally I wouldn't spend my time doing it. If I remember correctly they cut the old cable off, drilled out the knob and siver soldered it onto the new cable. | | | | | Joined: Aug 2008 Posts: 52 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2008 Posts: 52 | For my 54's cables I held the stem that the knob attaches to and held it a bench vise, then I heated the stem with a propane torch just enough to where I was able to pull the knob off the the stem. Then i used 5 minute epoxy to attach the old knob to the new cable. | | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | I found a throttle cable/knob at a swap meet but the cable was too short. I cut it off and put the shaft/knob in a lathe and drilled a hole in the end. The local piano rebuilding shop miked my original wire and gave me a piece of piano wire the same diameter which I brazed onto the shaft/knob. Wire free, knob/shaft one dollar, brazing fifty cents. End results? Priceless! That was 10 years ago and it is still intact. | | |
