8 members (Maybellene, tclederman, RoadsScholar, DadsFirstPickup, baldeagle, MickeyP, Stovebolt48, 1 invisible),
198
Mod | | | Forums66 Topics128,108 Posts1,056,231 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53831 12/22/2005 5:44 AM | Joined: Feb 2005 Posts: 42 Apprentice | | Apprentice Joined: Feb 2005 Posts: 42 | Any tips for a first-time transmission installer?
I have the transmission (SM420 4-speed) on a transmission jack doohickey that lets you tilt it. The input shaft is bumping around somewhere in the vicinity of the pilot bushing, but damned if I can get it aligned properly to go in. Frustrating!
If the answer is just "play with combinations of height adjustment and tilt adjustment until it goes in," that's OK, just let me know, but if there's some magical alignment trick to guide the process, man, that would help tremendously. | | |
#53832 12/22/2005 5:57 AM | Joined: Nov 2004 Posts: 117 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2004 Posts: 117 | First make sure the pressure plate is in alignment (you can use an old input shaft or buy an inexpensive alignment tool at your auto parts store. Take a long bolt the same diameter as the transmission mounting bolt and put it in one of the transmissions "ears" and use it to help align the transmission. Just gotta hold your mouth right.
cgresham1212 If you don't drive it, why have it? 55 1st Series 3100 5 window
#53833 12/22/2005 6:02 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | M. Rhoten,
Someone must have told you about an alignment tool..right! No! You must not have installed a new clutch and pressure plate otherwise this issue would have come up.
Without a dummy input shaft or a wooden alignment tool it can still be done. Using the cool doohickey to level the tranny, run the snout into the bellhousing and put it through the throwout bearing and into the clutch splines.
Have the transmission in gear (low) so you can turn the output shaft which will turn the input shaft and make it easier to engage the clutch splines.
You have to have a helper in the cab to depress the clutch which allows you to wiggle it around and find the pilot bearing...hold your breath, wiggle and twist and it will go right in.
Stuart | | |
#53834 12/22/2005 7:26 AM | Joined: Feb 2005 Posts: 42 Apprentice | | Apprentice Joined: Feb 2005 Posts: 42 | Sorry, I should have mentioned - I used an alignment tool when putting the pressure plate and clutch disc on. I am a rookie, but not that bad of a rookie  I do have the splines engaged - I'm just less than an inch away from the transmission being flush to the bell housing. It feels like the input shaft is bumping the side of the pilot, or perhaps the flywheel, so I figure I'm just needing the alignment to get that front part of the input shaft to hit the hole in the pilot. I will get a helper and fish around some more. Thanks for the words of encouragement! | | |
#53835 12/22/2005 1:05 PM | Joined: Sep 2003 Posts: 324 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 324 | Get yourself a couple of 3/4 x 4 in bolts and cut the head off of them and taper the ends where you cut the heads off. Then cut a slot in the bolt for a screw driver at the tapered end. Screw these bolts into the top holes of the bell housing for alignment bolts. Inastall the transmission on the upper bolts and use them for a guide. Works every time. These alignment screws can also be used when installing a 6 cyl head to keep your gasket in place when installing the head. Hope this helps it worked for me and saved me from having a couple of sore arms. Tom | | |
#53836 12/22/2005 5:43 PM | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Rhoten,
Did you replace the pilot bushing? If yes, are you sure it's sized correctly?
Did this transmission come out from where you are trying to put it?
Paul | | |
#53837 12/22/2005 5:55 PM | Joined: Mar 2005 Posts: 1,029 Member | | Member Joined: Mar 2005 Posts: 1,029 | You might try the alignment tool again to make sure no one accidently depressed the clutch and allowed the clutch disc to fall while you were installing the transmission. | | |
#53838 12/22/2005 6:04 PM | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | alignments pilot guides are about $2.80 at FLAPS southern auto/ carquest etc...
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
#53839 12/22/2005 6:30 PM | Joined: Feb 2005 Posts: 42 Apprentice | | Apprentice Joined: Feb 2005 Posts: 42 | Yeah, it's a new pilot. I checked it against the old one and it looked identical. This trans came out of the same truck, so I figure it's just skill (or lack thereof) on my part, rather than parts fitment.
I will try the trick with the bolts - that's a good idea. I notice the shop manual specifies using alignment pins in those upper holes, so trying to emulate that is probably not a bad idea.
Guess I'll head out with my two year old son to Tacoma Screw! | | |
#53840 09/26/2007 8:21 PM | Joined: Oct 2005 Posts: 62 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2005 Posts: 62 | I could have wrote this original post word for word last weekend. My first attempt at a transmission install and it just wouldn't go in all the way. the output shaft of the tranny turned as I turned the crankshaft pulley up front so I knew the splines were engauged, but the sm420 mounting flange just wouldn't meet the bellhousing, it was 1" away :hammering: . I did a stovebolt search, found this thread with these words of Automarc, which were golden Originally posted by atomarc: M. Rhoten, You have to have a helper in the cab to depress the clutch which allows you to wiggle it around and find the pilot bearing... Stuart Once I depressed clutch pedal, tranny slipped in like a hot knife thru butter, thanks again fellow stovebolters for sharing some knowledge. Truckstein
I see a GM truck in your future!
#53841 09/26/2007 9:04 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Truckstein,
Mama Atomarc didn't raise no dummies...if only the doctor hadn't dropped me on my head! :whistle:
Stuart | | |
#53842 09/27/2007 12:17 AM | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | To go the final distance, I used my feet on the back of the tranny and moved it in. I also used the guide bolts in the top. | | |
#53843 09/27/2007 12:35 AM | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i have also had problems with the plastic install tool not being as good as a old shaft i cut off. there was more slop with the plastic tool causing it to not be aligned perfect. i have always had to do it by myself so i have never had to push in on the clutch, you could ptob put a block on it to hold it in. | | |
