8 members (66flea, Southerntruck, Otto Skorzeny, GMCJammer51, Phak1, TGP, DadsFirstPickup, Wayne67vert),
118
Mod | | | Forums66 Topics128,049 Posts1,055,682 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | I'm looking at picking up another TF truck, this time a 58 1/2 ton panel. I have an image seared in my head from a younger me of a TF panel sitting on mudders looking very aggresive. I understand a 60-72 rear diff is a pretty good fit, how about the front out of a K10? Does anybody know if the track width is reasonably close?
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Should work fine. I would really suggest going with a '71 or later axle to get away from the closed knuckle front end. The Open knuckle versions are stronger, have a tighter turning angle, and also have disk brakes (brake upgrades are VERY important with large mudder tires). If you're planning on a really serious tire size (33" or larger) I would advise at least a 3/4 ton axles, 1 ton would be better. Thsi is both for the extra axle capacity to handle the weight of the tires, and also for the larger brakes to slow them down. There's also the safety factor of having the full floater on the rear, no chance of losing a wheel should an axle shaft break.
Bill Burmeister | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | Bill Ive never even thought about an axle breaking and losing a wheel. Then again Im not an offroader either. Good to know information anyways!  Jeff | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | When you deal with the semi-floating C-clip axle, which is found under virtually all GM 1/2 ton and some late model 3/4 ton trucks, the only thing holding the axle shaft in is that clip. So when the axle breaks, the shaft can spit right out. The full floater puts the load on the housing, not the axle, as well as being the retainer for the hub. So if the axle breaks, the hub and wheel stay on. And if it's got a locking diff, the truck can still be limped home, eliminating a tow bill. It is best to remove the broken shaft peices fist, though, to prevent any further damage.
Bill Burmeister | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | If I go through with the purchase it won't be lifted, but stock height which I believe will limit me to about a 30x9.50x15. Now don't get me wrong, I;d love to go to 1 ton running gear and a few inches lift, but i'm going to be trading lots of hours of labor for a disassembled panel as it is. Early 70's era trucks are common as dirt in my area. It would never get used offroad, but all for looks.
Devin
