1 members (Hotrod Lincoln),
92
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53783 12/20/2005 5:32 AM | Joined: Oct 2005 Posts: 28 Member | | Member Joined: Oct 2005 Posts: 28 | This is all new to me and I am mechanically challenged. I want to put a 235 in my 48 and want to put a 3 or 4 speed transmission with floor shift and open driveline in it since I am updating the rearend to a 64 with 3:73 gears. I have read alot on this site about transmissions but I need one that will bolt right in with the floor shifter in the right place. Can I just try to find one out of a 55 2nd -62 truck or what. I just want to be able to drive on state routes and back roads without the engine winding out. Help! | | |
#53784 12/20/2005 5:11 PM | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | You may be on the right track with the 55 to 62 unit. That 4 speed is a floor shift and would be my choice for an easy swap and should be inexpensive. There is an overdrive T-5 unit that is very popular now. You should read all the threads and tip on this site and over at inliners.org re the T-5. | | |
