3 members (IHPWR, Phak1, TPR57C), 73 guests, and 1 robot.
Topics128,157
Posts1,056,877
Members48,458
#537775 05/14/2009 9:23 PM
Ok so I got everything out of the cab and am trying to get the tar off of the inner part of the cab, in some places I can pull it right off and that part of the cab looks great, In other areas it is a patch of lining/tar and dirt and it wont budge. I have tried goo be gone and a floor scraper. Im at a loos here.
1953 GMC 3/4-Ton Truck
Wanna know more about me heres my Myspace
Heat-gun and scrape.
Maybe a paint remover will loosen it a little.
In my 54, it simply took a lot of work to loosen it and scrape it off.
If it's straight tar, I've always found that paint thinner works well to dissolve it.
Harbor Freight heat gun $10 and a set of $3 scrapers (you can chuck the scrapers when you finish and if you burn up the gun you won't feel bad). Heat it until it starts to bubble just a bit, let it cool for a few seconds and the scrape it off.
Thanks all, I have a ton of scrappers, I'll go buy that heat gun and I have a ton of paint thinner.
calhere...I'm suprised you're having probs...My truck came from So-Cal and every bit of tar board was like Bakelite!
It was baked to death and flaked off easily.
Maybe I was just lucky.......
Hope you get it all off.
Good luck.
More pix on Flickr.
Mine came from up north in the mountains.
