1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
i install a sb350 chevy and was wondering if anyone know what hose part numbers will fit. the top hoses goes straight from the thermostat to the radiator at 6 oclock position . the thermostat hose connection was at the 4 oclock position and it was changed to the straight one. thanks for help. need for top and bottom hose. using stock radiator.
1953 Chevy 3/4-Ton Stakebed
[url=http://fiftythree-chevy-flatbed.tripod.com/
most folks have digital clocks, they never change position wink take a piece of stiff wire [coat hanger will do], bend it to the exact shape and length you need and head to the parts store - don't fergit to measure the diameter
The top hose is easy. Just measure the diameter needed and go get a flexible hose the proper length at the parts house.
The bottom hose can be a little tricky. I recently got one that had the right "bend" in for my 37 and then cut it the right length. At first I tried a flexible hose but it kinked as it is very short for my application. (350 in my 37 with the radiator as close to fan as possible.)
So, I ended up getting a hose with the right "bend" in it and cut it to length. Be sure to cut it a little long to begin with because when you slide it up onto the "necks" it will need to be about and inch or two longer than you think!!!
NOTE: since the bottom hose with the bend in it had no wire in it like the flexible hose I pulled the wire out of an old flexible hose I had and cut it to length and stuffed it down in the new hose with the bend. That way I know the molded hose will not completely ever collapse!
Just hope this helps in some way....... also know I bought, and took back 4 hoses before I got the one I needed!!!
Try a lower hose from a 65 V-8 truck. I have used them for V-8 conversions in TF trucks. It has the correct bend on the water pump end, you just have to cut the radiator end as required to fit.
Fred
