4 members (Wayne67vert, Wally / Montana, moparguy, Pete1946), 130 guests, and 1 robot.
Topics128,072
Posts1,055,903
Members48,429
#535862 05/08/2009 3:33 AM
I want to add LED brake lights to my street rod. I would like to do the construction or build myself, ok..I'm cheap. Trouble is, I can't seem to find a source of a kit that I can cut the board to fit my tail light housings and the mount the various components, etc. Does someone out there know of a place to get a "kit" for us that build 'em. Thanks in advance.
#535903 05/08/2009 5:40 AM
Jim & Caroline
You can get LED bulbs for single or double contact sockets at West Marine
http://www.westmarine.com/webapp/wc...m=5002&subdeptNum=9&classNum=139
Thanks for the info guys. I must have understated my request. I am looking for a board or card that I can cut to fit my unique light housings then mount as many SDM type LEDs as will fit. Maybe put a driver chip behind it for dual intensity. My background is instrumention and process control so I should be able to handle it if I can find the parts. As always, thanks.
Joe W. #536767 05/12/2009 12:38 AM
Thanks again guys. The information you passed on will serve me well. I decided to remove the lamp housings and modify the 'inners' to accept a 1157 type led lamp for now. The car show season is upon us and I gotta go. I had to set the socket back fron the lens about 1/2" more than orginal so the taller led lamp will clear the lens, which required me to fab a new mount for the socket. I found some very weathered (frayed) cloth insulated wire hidden behind the mount, so I'm glad I went to the trouble. Anyway, if all works out I'll build my led boards over next winter so everybody will be able to see my tail feathers even better.
