0 members (),
172
Mod | | | Forums66 Topics128,101 Posts1,056,182 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | I want to add LED brake lights to my street rod. I would like to do the construction or build myself, ok..I'm cheap. Trouble is, I can't seem to find a source of a kit that I can cut the board to fit my tail light housings and the mount the various components, etc. Does someone out there know of a place to get a "kit" for us that build 'em. Thanks in advance.
| | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 |
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Thanks for the info guys. I must have understated my request. I am looking for a board or card that I can cut to fit my unique light housings then mount as many SDM type LEDs as will fit. Maybe put a driver chip behind it for dual intensity. My background is instrumention and process control so I should be able to handle it if I can find the parts. As always, thanks.
| | | | | Joined: Mar 2008 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2008 Posts: 54 | | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Thanks again guys. The information you passed on will serve me well. I decided to remove the lamp housings and modify the 'inners' to accept a 1157 type led lamp for now. The car show season is upon us and I gotta go. I had to set the socket back fron the lens about 1/2" more than orginal so the taller led lamp will clear the lens, which required me to fab a new mount for the socket. I found some very weathered (frayed) cloth insulated wire hidden behind the mount, so I'm glad I went to the trouble. Anyway, if all works out I'll build my led boards over next winter so everybody will be able to see my tail feathers even better.
