1 members (53 green 1- ton), 110 guests, and 1 robot.
Topics128,072
Posts1,055,907
Members48,429
#524835 04/05/2009 6:16 AM
Hey Everyone
I am in the process of getting ready to put the trim on the side of my 1965 C10 long box fleetside. My truck was not orginally a custom cab which brings about my issue. I was wondering if anyone had the specs on where the trim is supposed to be. I am ready to drill the holes to put the clips on for the trim but want to make sure I do it in the right place. I don't have the shop manual for the truck but was wondering if anyone knew for sure if this info was in there or not?
Dan
k10 Offline
Yes, it is in there.
k10 #534742 05/04/2009 4:14 PM
The trim starts just above the tire well flare on the front fender, or about 1 inch below the crease in the body.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
http://community.webshots.com/user/Apachetrucks Take a look at my NEW folder in webshots. This my help you. I don't have the main shop manual but I do have the supplement and there is zero in it concerning trim placement. Hope this helps you, thanks, hobert
"The Lord is my shepherd"
The shop manual does not cover trim placement. The assembly manual does. Get yourself a reprint of the factory assembly manual, it is money very well spent. It is a fantastic book chuck full of valuable information.
1963 Chevy C20 Longbed Stepside
1978 Chevy K30 Custom Deluxe
Certified Bolt Nut
Certified Bolt Nut
Hey bears, this might be a dumb question..but I'll take the bait. I'm sure there are others who might want to know where to get a copy of the assembly manual. Thanks
Many different vendors have them. Classic Parts and LMC Truck are a couple but many other vendors have them as well. As a sidenote, the assembly manual can be tough to use in a way because there is no index, table of contents, or page numbers. You have to thumb through it until you find what you need, but it is still a treasure trove of info.
Wanted to give an update that using the assembly manual I purchased off od Ebay did the trick. Gave lots of measurements to get the holes in the right spots. Was quite nerve racking drilling them but the finished product looks great! So glad I did it.
