1 members (Hotrod Lincoln),
73
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,055 Posts1,055,782 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 5 New Guy | | New Guy Joined: Apr 2009 Posts: 5 | Hey Everyone
I am in the process of getting ready to put the trim on the side of my 1965 C10 long box fleetside. My truck was not orginally a custom cab which brings about my issue. I was wondering if anyone had the specs on where the trim is supposed to be. I am ready to drill the holes to put the clips on for the trim but want to make sure I do it in the right place. I don't have the shop manual for the truck but was wondering if anyone knew for sure if this info was in there or not?
Thanks Dan | | | | | Joined: Aug 2000 Posts: 800 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 800 | | | | | | Joined: Mar 2009 Posts: 100 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2009 Posts: 100 | The trim starts just above the tire well flare on the front fender, or about 1 inch below the crease in the body.
It's better to have it and not need it, then it is to need it and not have it. "Woodrow F. Call"
| | | | | Joined: Feb 2005 Posts: 199 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 199 | http://community.webshots.com/user/Apachetrucks Take a look at my NEW folder in webshots. This my help you. I don't have the main shop manual but I do have the supplement and there is zero in it concerning trim placement. Hope this helps you, thanks, hobert
"The Lord is my shepherd"
| | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | The shop manual does not cover trim placement. The assembly manual does. Get yourself a reprint of the factory assembly manual, it is money very well spent. It is a fantastic book chuck full of valuable information.
1963 Chevy C20 Longbed Stepside 1978 Chevy K30 Custom Deluxe
| | | | | Joined: Nov 2007 Posts: 131 Certified Bolt Nut | | Certified Bolt Nut Joined: Nov 2007 Posts: 131 | Hey bears, this might be a dumb question..but I'll take the bait. I'm sure there are others who might want to know where to get a copy of the assembly manual. Thanks | | | | | Joined: Oct 2008 Posts: 321 'Bolter | | 'Bolter Joined: Oct 2008 Posts: 321 | Many different vendors have them. Classic Parts and LMC Truck are a couple but many other vendors have them as well. As a sidenote, the assembly manual can be tough to use in a way because there is no index, table of contents, or page numbers. You have to thumb through it until you find what you need, but it is still a treasure trove of info.
| | | | | Joined: Apr 2009 Posts: 5 New Guy | | New Guy Joined: Apr 2009 Posts: 5 | Wanted to give an update that using the assembly manual I purchased off od Ebay did the trick. Gave lots of measurements to get the holes in the right spots. Was quite nerve racking drilling them but the finished product looks great! So glad I did it. | | |
