5 members (Hotrod Lincoln, Oswald, fonz8261, baldeagle, squatchie86), 74 guests, and 3 robots.
Topics128,014
Posts1,055,333
Members48,419
#532459 04/26/2009 11:33 PM
Apprentice
Apprentice
Will a diff out of a 55 chevy fit into a 52 chevy. I want to get rid of the torque tube diff on my 52 What is all involved to do this Thanks Greg
gregs 52 #532465 04/26/2009 11:40 PM
52 to 55.1 definitely. 52 to 55.2-59, maybe. Get out the tape measure.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
55 tractor #532538 04/27/2009 3:30 AM
Yes, it can be done. I beleive it might be just a tad wide, but not enough to cause a problem. Another option would be to weld up the pivots on the spring pads, then just use the 3rd member from the '55 rear to get the open driveline.
Bill Burmeister
LONGBOX55 #533310 04/29/2009 5:42 AM
The third member from the 55 will bolt right in to your 52 rear axle and will give you an open drive. As mentioned above the pivot points will need to be welded once you set up your pinion angle. You will have to change your transmission too.
1949 Chevy 1/2-Ton
"Sedgewick"
1989 Caprice
Sedgewick #534439 05/03/2009 1:17 PM
Apprentice
Apprentice
I'm thinking about this swap for my 51, but want to use the original wheels. Will the axles from the 51 work with the 55 third member?
Tarheel
tarheel #535317 05/06/2009 3:51 PM
V
V Offline
I am also interested in an answer to this question...I have a 53 and would like to convert my rear to open drive and would like to keep my original 16" rims. Anybody know?
vinsanity #535334 05/06/2009 4:52 PM
Yes your axels will work. I put a 55 third member into my 46 rear end. Used the 46 axels and kept my original wheels. It's an easy swap. Just make sure you weld up your spring perches or weld on new ones.
George
46forme #535644 05/07/2009 3:25 PM
Thanks for the helpful info 46forme....now I just need to locate the parts!
na
slow cheetah #535691 05/07/2009 6:30 PM
1 Offline
i believe the center section up to 60' will bolt in.
10 micron #535857 05/08/2009 3:18 AM
1955-62 1/2 ton use the same center section.
My Blog
