0 members (), 129 guests, and 1 robot.
Topics128,115
Posts1,056,292
Members48,439
I have to assume the power supply on my '63 Grumman 292 is a generator, correct?
Question 1} how to tell the difference between a generator and an alternator?
2} What are the steps for switching to an alternator?
On yesterday's test run, I found that I am not making enough juice to run the large inverter I installed. This inverter is intended to run a small electric refrigerator and 5000btu AC unit during travel. The 120vac power needs when stationary will be from direct hook-up to an AC outlet or from a portable AC generator.
Ex Hall Monitor
Ex Hall Monitor
For the most part a generator is long and black while an alternator is about half as long, bigger around and silver. I don't have any experience with an inverter so I can't comment.
you won't find an alternator that'll support that inverter load and still leave enough power from a 292 to move the truck, you should be looking for an RV 3 way fridge and using vehicle AC
Have you priced a 2 or 3 way frig?
After further inspection, it looks like it has an alternator, obviously underpowered. I am thinking an HO alternator, battery isolator and 2nd battery may do the trick.
The temptation to simply run the portable generator is strong. all I have to do is move an AC inlet to the rear bumper deck. Certainly cheaper!
yes I have, and investigated all the alternatives, which is why I'm going with a top line DC only marine fridge wink no point in wasting money buying constant frustration ....but in your case, a propane/110 fridge could easily be found used very reasonable
here's a bit about bigger alternators [biggest you could use], but a 2nd battery will just add to the load, even if you use deep cycles .... I'd suggest spending some time studying mobile electrical systems - with that van you have the perfect platform for solar panels
Red, I love Da Bus! Sa-weet!
my rv has a regular alternator and 2 batteries with a isolator the engine battery only runs the engine part and the coach battery runs my fridge, tv, microwave, pc, etc ,etc with no problems if the battery for the coach gets drained the isolator keeps power from being drained from the engine battery. in turn only the battery that needs charging at the time gets charged by the alternator breaking up the load so to speak also, my ac to dc converter also has a charger built into it so it charges the coach battery when were plugged into shore power. how ever our fridge only runs for a breif time to cool the food store and then stays closed and cold untill hooked to shore power. for long drives the fridge thermostat kicks it back on when it needs to cool. hope that helps
1966 Chevy C/60 Wrecker
Story in the Gallery
Pictures on Flickr
It don't rust if you run it hard enough
http://images.google.com/imgres?imgurl=http://www.rowand.net/Shop/Tech/images/GmGeneratorAndAlternatorComparison.jpg&imgrefurl=http://www.rowand.net/Shop/Tech/GmAlternatorIdentification.htm&usg=__r4a3v8YhearfR56J9uXRKo6qecM=&h=560&w=384&sz=30&hl=en&start=1&tbnid=jTiezT1l_NfTRM:&tbnh=133&tbnw=91&prev=/images%3Fq%3DGM%2Bgenerator%26gbv%3D2%26hl%3Den%26safe%3Dactive
Jim & Caroline
