7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible), 97 guests, and 8 robots.
Topics128,106
Posts1,056,213
Members48,436
#53441 12/13/2005 7:51 PM
a fellow bolter has a 53 rear end for sale that he has updated to 3:55 ratio. my question is, will a 53 rear end be a direct swap to my 54?
54 3100 w/62 235 "Yosemite Sam"
Born a Jay Hawk, raised an Okie and resurrected in Texas!http://community.webshots.com/user/djed50
2 Offline
djed50 if you have a torque tube rear end there should be no defference in the 53 and 54 modles of trucks as they both had a 4.11 gear. They did not change until the 55 1st series when they went to the open drive line. I am sure there outhers that can and will verify my information.
Tom
thanks tom - i was thinking the 54 had a 3:9 something. i guess what i was really wanting to know is if the spring perches, width etc were all the same and if it would be a straight "take off the 54 rear end and bolt on the 53 with the new gears in it".
Anonymous
Unregistered
Anonymous
Unregistered
The only issues in swapping the two axles is that the rear spring pads on some 54 axles are different from earlier years. I found this out when I compared my 54 to a 51.
The 53-54 passenger car rear was 3:70 behind a stick and 3:55s for the automatic. But check it out!
1946 1/2-Ton Chevy
'54 should be the same as earlier years. '55.1 would be different for the open driveline axles.
1954 GMC De Luxe COE
thanks guys, you have been a big help as always!
