9 members (Wickedbass, Gabes-trucks, Ponchogl, Otto Skorzeny, 52Carl, dt235sd, BC59, 2 invisible), 153 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#534033 05/01/2009 9:39 PM
I have a set of visors, but not sure what year they're for.They are a cardboard material if that helps. Here's a pic:
http://i39.photobucket.com/albums/e177/PursuitSpecial/ebay%20stuff/sunvisors1.jpg
I
Doug
Last edited by GMONIZ; 05/02/2009 4:13 AM. Reason: EDITED CONTENT TO QUESTION ONLY
Somebody had posted a reply that had a link to help me find out what these visors were for....where did it go??? What were the problems regarding my original post being edited? I know it was moved and that's fine but....????
without looking I bet it was moved to the interior forum....but even when its moved the topic stays where you put it. If you click on it then it wills say "this topic has been moved" and if you click on those words it will take you to the forum to which it was moved to.
Is this clear??? smile
EDIT: the visors look like the ones off my 52 panel...or at least they look close from what was left of mine.
To give an answer as to what they fit, they appear to be for a '55-'59. They're identical to the ones on mine.
Bill Burmeister
The fact that George edited it first suggests it probably was somewhere in the swap meet. However, if there were replies when it was moved, they would have moved with it.
Now I'm moving it to Interiors. Good luck
3rd time moved but I guess it's in the right place now so all is well. Thanks to those that have shed some light on this for me....the truck scene is a new thing for me so I have a LONG way to go.
Thanks again guys!!
Doug
Moderated by  ndkid275, Phak1
