3 members (Jay R, Hanks custodian, 1 invisible), 122 guests, and 1 robot.
Topics128,052
Posts1,055,727
#533630 04/30/2009 5:34 PM
I was wondering if the brake flange( or, brake backing plate) from an early '50 to '60 rear brake set-up would readily bolt up to the axle of my '49. I'd like to be rid of the Huck Brake system.Wish I had checked this out before I invested in the new bearings, pinion and ring. If you happen to have a truck catalog from "obsolete chevy" a review of the top and bottom of page 52 will give you an Idea what I'm getting at,It appears as if the flanges would readily change-out Any opinions??
tools94 #533637 04/30/2009 6:05 PM
It will work. You will have to drill out a couple of the bolt holes in the arms and spindles from 7/16 to 1/2.
Not a big problem.
You will go from huck to bendix.
Dennis
Check the tech tips under brakes. The guy talks about swapping with the 51 bendix brakes, I believe.
Riding in the Passing Lane
If it's 1/2 ton the 51 up Bendix can be used. The 50 back were the huck brakes.
1972 Chevy c10 Cheyenne Super
Whew!! beautiful afternoon here in NC. just got done abusing the lawn and much pleased w/the response. Had a hunch that plate would match up, now the search for a rear in those years will begin. Thanks again fellas!!!
