7 members (wilbur53, stlcardinalsguy, Wally / Montana, King Kielbasa, joe apple, Hotrod Lincoln, Otto Skorzeny),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,052 Posts1,055,727 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 502 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 502 | Fish eyes are due to something on the surface like oil, silicone. If you are sure the surface is clean I'd look at the spray equipment to make sure the contaminates are not getting in that way. You could also try a fish eye eliminator in your paint mix. Shoot your first coat a little dry, I mean don't try to get full coverage with the first coat and leave the wet coat for the final coat.
Dan
Remember your freedom - US Veterans provided it. 101st Screaming Eagles
| | | | | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | Remember to clean the parts first, and before you blast them. It could also be contaminants in the bead blaster. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Steve beat me to it. Always-ALWAYS clean first. Any contaminant on the surface can be driven into the metal's pores by abrading, whether it's sandblasting or sanding. Once it's in the pores it can be difficult to get out. You've just learned a lesson you'll remember for a lifetime.
| | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | thanks builder and tiny yeah il probley remember it for the rest of my life i was so disapointed when it started to fisheye. now i know clean clean clean i should have known that because i have to clean all my hobbies befor i do them {rc helicoptors} thanks agin perry | | | | | Joined: Feb 2008 Posts: 102 Shop Shark | | Shop Shark Joined: Feb 2008 Posts: 102 | Was your neighbor using something like Armor All or Vinyl Guard? The silicon in those will destroy even the best painters paint job | | | | | Joined: Jan 2009 Posts: 86 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2009 Posts: 86 | no my closes neighbor is a quarter mile away so im pretty sure it was my fault not getting it clean enuff the first time | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | One more bit to add. When you clean always use more than one cloth. Use a clean cloth to wipe the cleaner off while it's still wet. If whatever cleaner you use is allowed to dry on the surface all you've done is move the contaminant around. Don't be shy about using as many clean cloths as necessary to do the job right.
| | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | Another source for contamination is the air compressor, be sure to drain the compressor, and use an in line final water trap on the paint gun. Also the natural oil from your hands will cause problems with paint. | | |
