| | | Forums66 Topics128,090 Posts1,056,443 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2007 Posts: 46 | I am ready to install the 261 in my 39 1/2. It appears that I will not be able to use the stock oil pressure gauge. I hate the thought of having an under the dash add on aftermarket gauge. Is there a better option that would appear to look stock? | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Id just use the stock one, if it's pegged you got plenty of pressure. Then put a small 80# one in the line in the engine compartment, that would be my approach. Unless you want the EXPENSIVE after market stuff. | | |
