11 members (Jay R, TUTS 59, Forty9, cmayna, Lostbuthaulinass, Woogeroo, Peggy M, Wayne67vert, Uncles51, greenie-reddy, 1 invisible), 105 guests, and 2 robots.
Topics128,134
Posts1,056,411
Members48,441
Pretty soon I'll be hooking up my 283 to a T350. The 283 doesn't have a block mounted starter so I will have to use a starter mount adapter plate. At this point I'm trying to figure out what components will work together. The starter I have is from a '61 283, I believe. I need to figure if that is going to work with the adapter plate and the T350 flexplate or if I need to find another starter. How many teeth on a T350 flexplate?
Mike
1958 Chevy 3200 Fleetside
1958 GMC 100 Wideside
Did you get free advice today? To donate to this site using PayPal is fast and EZ. Click here: http://www.stovebolt.com/office/thanks.html
168 teeth I believe. Wait, the T350 doesn't have teeth on it, the flywheel hooked to the engine has the teeth. The converter should bolt to any of the flywheels. You have to match your starter to the flywheel, then hope it has the right bolt holes for the converter. T350 use a smaller bolt circle then the T400, I am not sure about the powerglide. Go to Summitracing.com and check out flexplates. You should find something that fits.
Joe
168 or 153 depending on the diameter.
