4 members (Otto Skorzeny, Gray_Ghost, BarryP, Jeff Ogden), 117 guests, and 1 robot.
Topics128,147
Posts1,056,805
Members48,454
I know they used the clutch-head bolts/screws at least through the '62 model year, because I've got them on my truck.
Did they carry them thru the '66 body style?
And more importantly, when did they stop using them?
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
"when did they stop using them?"
Not soon enough!!!!!! grin
~Jim
i have never seen one on 64 to 66 and i have had several. my 63 has a few but not many. i bet 63 is the last year.
my 46 GMC has no clutch head bolts. Did GMC use them?
1946 GMC 1/2-Ton Pickup
Id hasten a guess that the '60-66 trucks were the last to use them. Maybe even partially through those years. ohwell
My 1953 Chevrolet
1947.1 Gallery
Jeff'z,
The only GMC's that had clutch head bolts, were trucks that were built at a chevy Plant. Some GMC's were built at Chevy plants for a while. If you see a GMC with clutch heads, it was probably built at a Chevy plant.
That's one of the little things that made a GMC different from a Chevy.
What were they thinking when they invented the clutch head anyway?
Same reason they use a Torx head...
So mechanics have to go buy one more tool. dang
They stick onto the end of a power screwdriver better than a Phillips head screw. It was an assembly line speed thing. Torx was used for the same reason, but they were used with robotic assembly tooling.
