7 members (Guitplayer, FAST55, Leo, Oldcaliforniakid, lc_btv, MikeE, Jay R),
83
Mod | | | Forums66 Topics128,050 Posts1,055,673 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53207 12/07/2005 2:16 AM | Joined: Nov 2003 Posts: 70 New Guy | | New Guy Joined: Nov 2003 Posts: 70 | I have the chanc to buy a 61 GMC 1/2 ton 4x4. It has the original 305 V6 that is worn out. I would like to replace it with a sbc. What's involved with this swap? I'm concerned with motor mounts, mating the sbc to the original 4sp, clutch, flywheel and any other info I can get on this conversion. Thanks | | |
#53208 12/08/2005 12:14 AM | Joined: Jul 2005 Posts: 3 Junior Member | | Junior Member Joined: Jul 2005 Posts: 3 | i too am about to swap my 305A in my'60 for a 350 small block. From what i have heard the bell housing should have the same bolt pattern..........but have not research much of this due to the cost of my 350 rebuild and my 305 is still runnin strong. I too would be interested in any info you do find. | | |
#53209 12/08/2005 2:36 AM | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | If this is an original 305A V-6 then the bell housing is different to a 350. You will need a bell housing for the Chevy V8 with the hydraulic clutch slave cylinder mount. Get one for a 60 or 61 Chevy pickup that had a V-8 and it should work. | | |
#53210 12/08/2005 3:28 AM | Joined: Dec 2005 Posts: 2 Junior Member | | Junior Member Joined: Dec 2005 Posts: 2 | "Back in the day" when these v6's first came out this was a pretty standard swap. Main thing is the bellhousing. I do not remember all the details, but I think the mounts matched, just make sure the pads are the same. Then look at the gas linkage. Used to be really easy, when we went to the yard and scavenged a V8 Chevy to fix up the V6 Jimmy. Good luck. John v L | | | | | Joined: Nov 2020 Posts: 4 Moderated | | Moderated Joined: Nov 2020 Posts: 4 | I am trying to do this engine swap in my 1966 GMC k1000 with a sm420 4 speed. Do you know what bell housing I need.
Thanks Billypylot | | |
