0 members (),
37
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2007 Posts: 293 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2007 Posts: 293 | I've read several dozen posts on this topic but didn't find the answer to a simple question. What are the advantages of converting to HEI? I assume reliability is one of them (no points and condenser), but is that it? Could I also expect better fuel economy, more power, easier starting, better idle, or what?? I want my truck to look stock, but reliability is probably more important to me. I plan to drive this Bolt. Thanks. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | I have an HEI in my 46, does ALL that you mention on your wish list. To look 'stock' get the Mini HEI that Tom Langdon has, while it does not look totally stock it's small and most folks will never know. I've been very happy with all his products, never a problem. This definitly what you want in your driver. | | | | | Joined: Jan 2008 Posts: 493 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 493 | This is just my opinion. You could say yes to all. Since the output to the spark plugs is constant from an HEI system, as compared to points, once it is set your performance will remain the same over time. This would mean that you want waste fuel, start hard and idle like crap during the time that your point have moved out of adjustment. You wont have to deal with keeping your points adjusted to the sweet spot. Except for changing the plugs and checking the wires you wont have to mess with the ignition. Dwell time for the HEI is more of an on and off deal than points which allows your coil to recover more after a spark. You also get a higher voltage to the plug which at least on my MGA allowed me to open up the plug gap some. The higher output to the plugs means that as the plug gap widens with time there is more juice to make the spark jump the extra distance. That should give a more complete burn of the fuel. That being said a well adjusted points system probably would come close to working as well. The problem is they don't stay adjusted. That is why new cars don't have points. Some one will be along that knows more than I do about it but that is my guess. | | |
