Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (cmayna, baldeagle, Hotrod Lincoln), 52 guests, and 3 robots.
Topics128,006
Posts1,055,268
Members48,418
#532085 04/25/2009 5:26 PM
I've read several dozen posts on this topic but didn't find the answer to a simple question. What are the advantages of converting to HEI? I assume reliability is one of them (no points and condenser), but is that it? Could I also expect better fuel economy, more power, easier starting, better idle, or what?? I want my truck to look stock, but reliability is probably more important to me. I plan to drive this Bolt. Thanks.
norcal49er #532099 04/25/2009 6:39 PM
I have an HEI in my 46, does ALL that you mention on your wish list. To look 'stock' get the Mini HEI that Tom Langdon has, while it does not look totally stock it's small and most folks will never know. I've been very happy with all his products, never a problem. This definitly what you want in your driver.
1946 1/2-Ton Chevy
norcal49er #532100 04/25/2009 6:45 PM
This is just my opinion. You could say yes to all. Since the output to the spark plugs is constant from an HEI system, as compared to points, once it is set your performance will remain the same over time. This would mean that you want waste fuel, start hard and idle like crap during the time that your point have moved out of adjustment. You wont have to deal with keeping your points adjusted to the sweet spot. Except for changing the plugs and checking the wires you wont have to mess with the ignition. Dwell time for the HEI is more of an on and off deal than points which allows your coil to recover more after a spark. You also get a higher voltage to the plug which at least on my MGA allowed me to open up the plug gap some. The higher output to the plugs means that as the plug gap widens with time there is more juice to make the spark jump the extra distance. That should give a more complete burn of the fuel. That being said a well adjusted points system probably would come close to working as well. The problem is they don't stay adjusted. That is why new cars don't have points. Some one will be along that knows more than I do about it but that is my guess.
