0 members (), 191 guests, and 2 robots.
Topics128,089
Posts1,056,141
Members48,436
#53103 12/01/2005 6:41 PM
Junior Member
Junior Member
I would like some info on putting a int. dt466 deisel in a 1-ton. Any info would be nice.
#53104 12/01/2005 9:17 PM
Junior Member
Junior Member
1480 lbs, better have some good springs!
some interesting reading:
www.ic-corp.com/assets/pdf/DT466vsC7-bus.pdf
1969 GMC K/2500 (w.i.p.)
#53105 12/01/2005 11:51 PM
slowgo61,
The stock engine with clutch is about 585 lbs. The previous post indicates the dt466 weighs in at around 1480 lbs. This would be a massive engineering undertaking...did you get a free engine you need to use somewhere? Good luck and keep us updated.
Stuart
#53106 12/02/2005 6:12 PM
Junior Member
Junior Member
Thanks for the info. Now I have a reason to anther truck maybe 1 1/5 to 2 ton.
#53107 12/02/2005 11:40 PM
now THAT's an engine upgrade, what kinda trans are you gonna use and what's the power rating?
#53108 12/02/2005 11:43 PM
#53109 12/03/2005 2:25 AM
I am in the process of putting a Detroit Diesel 4-53T in a 48 2 ton. I have seen a few DT466 engines, and think you will have a very hard time getting it to physically fit in the sheet metal. My 4-53T will be about as tight a squeeze as can be done without much, or any, body work.
But like they say, nothing is impossible, just throw enough money at it..
Now think about this, can you unscramble an egg? Perhaps some things are impossible?...
•1952 Chevrolet 3800 pickup
---All pictures---
#53110 12/03/2005 2:38 AM
Quote
Just mount it on a pallet and hoist into the bed, done,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#53111 12/03/2005 10:25 PM
GMC used the smaller Detroits in big trucks during the AD years, but they also had some seriously larger front sheet metal.
1954 GMC De Luxe COE
#53112 12/09/2005 4:00 AM
Apprentice
Apprentice
I have done several diesel conversions i.e. chev 6.2l into dodge ram and IH 6.9 into 75 ford.TheDT466 is a great engine but physically too large to fit into anything much smaller than a 3 ton.Too long,tall,heavy,and needs a lot of cooling capacity and large tranny to take the torque.I measured it up once.To put it into a smaller truck would require very extensive surgery to sheet metal.Would be fun though.
#53113 12/10/2005 6:06 AM
How about a "Duramax" I have seen some for sell in a truck yard in Spokane,Wa. "never installed".
