2 members (Pre '68 Dave, Gib70),
179
Mod | | | Forums66 Topics128,089 Posts1,056,117 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#53103 12/01/2005 6:41 PM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | I would like some info on putting a int. dt466 deisel in a 1-ton. Any info would be nice. | | |
#53105 12/01/2005 11:51 PM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | slowgo61,
The stock engine with clutch is about 585 lbs. The previous post indicates the dt466 weighs in at around 1480 lbs. This would be a massive engineering undertaking...did you get a free engine you need to use somewhere? Good luck and keep us updated.
Stuart | | |
#53106 12/02/2005 6:12 PM | Joined: Oct 2005 Posts: 8 Junior Member | | Junior Member Joined: Oct 2005 Posts: 8 | Thanks for the info. Now I have a reason to anther truck maybe 1 1/5 to 2 ton. | | |
#53107 12/02/2005 11:40 PM | Joined: Nov 2004 Posts: 122 Member | | Member Joined: Nov 2004 Posts: 122 | now THAT's an engine upgrade, what kinda trans are you gonna use and what's the power rating? | | |
#53108 12/02/2005 11:43 PM | Joined: Nov 2004 Posts: 122 Member | | Member Joined: Nov 2004 Posts: 122 | now THAT's an engine upgrade, what kinda trans are you gonna use and what's the power rating? | | |
#53109 12/03/2005 2:25 AM | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I am in the process of putting a Detroit Diesel 4-53T in a 48 2 ton. I have seen a few DT466 engines, and think you will have a very hard time getting it to physically fit in the sheet metal. My 4-53T will be about as tight a squeeze as can be done without much, or any, body work. But like they say, nothing is impossible, just throw enough money at it.. Now think about this, can you unscramble an egg? Perhaps some things are impossible?... | | |
#53110 12/03/2005 2:38 AM | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | Originally posted by slowgo61: I would like some info on putting a int. dt466 deisel in a 1-ton. Any info would be nice. Just mount it on a pallet and hoist into the bed, done, Scott | | |
#53111 12/03/2005 10:25 PM | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | GMC used the smaller Detroits in big trucks during the AD years, but they also had some seriously larger front sheet metal. | | |
#53112 12/09/2005 4:00 AM | Joined: Dec 2005 Posts: 20 Apprentice | | Apprentice Joined: Dec 2005 Posts: 20 | I have done several diesel conversions i.e. chev 6.2l into dodge ram and IH 6.9 into 75 ford.TheDT466 is a great engine but physically too large to fit into anything much smaller than a 3 ton.Too long,tall,heavy,and needs a lot of cooling capacity and large tranny to take the torque.I measured it up once.To put it into a smaller truck would require very extensive surgery to sheet metal.Would be fun though. | | |
#53113 12/10/2005 6:06 AM | Joined: Jul 2005 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2005 Posts: 54 | How about a "Duramax" I have seen some for sell in a truck yard in Spokane,Wa. "never installed". | | |
