| | | Forums66 Topics128,204 Posts1,057,297 Members48,467 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2003 Posts: 20 New Guy | | New Guy Joined: Nov 2003 Posts: 20 | The parking brake cable portion that goes into the rear backing plates has a spring over the cable. Does the end of this cable slip into the notch on the lever or am I missing a part here? The old cable had a clevis made on it that fit into the notch of the parking brake lever. Should this be cut off the old and put on the new cable? TIA Don | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Don, its been a while since I had my 50 and do not remember that far back! But, on my 52 you pull the spring back and slip the cable down into the slot/notch of the lever. Yours may be different as its the Huck brake style. At least this will give you something to read until an expert gets her.
Oh, you can find the link around here somewhere to the online service manual a bolter has put together. That should help out a lot.
EDIT: how far are you from Spartanburg?? We will be having our Southern Stovebolters 2nd Annual Reunion the 30th of May. Think you can make it?? Send me a PM and let me know. I can put you on the mailing list.
| | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | Huck system ebrake has an end clip type arrangement (like a clevis) that connects the end of the cable to the lever. The new replacement cables don't have this, you have to use your old one off the old cable. | | | | | Joined: Apr 2009 Posts: 29 New Guy | | New Guy Joined: Apr 2009 Posts: 29 | yep and the other end off of the old cable reuse also I broke the bracket that holds cable up to the frame trying to spred it open enough to get new cable in but a fender washer and bolt through good side holds it up just fine | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | How do you attach a new cable to an old end fitting? I guess the originals were swaged together? | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | The end that attaches to the lever has a slot in it to spread open , put onto new cable end and crimp it closed. The yoke at the threaded end of your ebrake cable attaches to the cross bar with a clevis pin and cotter pin. | | | | | Joined: Nov 2003 Posts: 20 New Guy | | New Guy Joined: Nov 2003 Posts: 20 | Thanks guys this helps tremendously!!!!!!!
Don | | | | | Joined: Aug 2008 Posts: 52 New Guy | | New Guy Joined: Aug 2008 Posts: 52 | Jim Carter's has replacements for the clevis and the clip at the end of the cable, and they're very reasonable priced. I bought 2 new clips for the ends.
