1 members (Peggy M),
74
0
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Hello everyone - I just got done installing a CPP leaf spring kit. (Awesome product!) It lowered the rear end 4" inches, and was a breaze to put on. I have a 1970 Chevelle 10 bolt hooked to it. I am test fitting some 17" x 8" wheels. I ended up with about a 1" gap beteen the sidewall of the tire and the bed side. What do you all think? Too small of a gap? Here is a link to a picture showing the gap. http://rides.webshots.com/photo/2281443440100697713CUloSnThere are also some picts of the new suspension and the wheels as I was testing them on the truck. Thanks! Ross | | | | | Joined: Aug 2008 Posts: 230 Shop Shark | | Shop Shark Joined: Aug 2008 Posts: 230 | looks close .in a perfect world with no wild terrain it would not be an issue .myself i would like about 2". | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | with a solid axle, 1" is close, unless you have eliminated body roll, etc. I would look at getting a wheel with a different offset.
| | | | | Joined: Aug 2007 Posts: 1,082 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 1,082 | i have about a fingers clearance on my outer fender lip. no sway bar, and although i dont go racing around corners, i have no rubbing problems.
leonard | | | | | Joined: Jun 2005 Posts: 1,756 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 1,756 | Second Ratrodking. Mine don't rub but I have sway bars. | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Thanks everyone -
I wonder if I could put a thin wheel spacer in and maybe get longer studs. Can't go to much in the other direction otherwise I will have issues with the lip of the fender.
I would imagine that I will have to keep very close tabs on the tire pressures. I don't want the tire to bulge at all.
Thanks again everyone!
Ross | | | | | Joined: Jan 2008 Posts: 239 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2008 Posts: 239 | You'll probably be OK. It looks like about 1/2" in the pics, but as long as you have that much you're fine. Low profile tires, (which it looks like yours are,) don't bulge much at all due to stiffer sidewalls.
Devin
If you can't hose it out it ain't a truck
55 3100 63 Corvair Monza 64 El Camino 72 240Z 01 Suburban
| | | | | Joined: Oct 2005 Posts: 1,317 Shop Shark | | Shop Shark Joined: Oct 2005 Posts: 1,317 | Based on my own truck with a similar sidewall/box clearance, I added a rear sway bar and the bar eliminated any potential for contact, even when the bed is loaded. Of course the bars, both front and rear should be standard add-ons if you plan on hitting the open road.
Dave | | | | | Joined: Jan 2007 Posts: 136 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 136 | Hello -
True. I have an IFS kit on the front with a sway bar.
The motor that is being built is pretty stong and I want to make sure it can hook up well, so I am planning on installing a Competition Engineering ladder bar kit that is designed to be used with leaf spring suspensions.
I see they have a panhard bar piece that can be added to the ladder bar kit. I might have to look into that.
Thanks for the advice Dave. | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | From my experience you will need 1 1/2" - 2" tire clearance to the bed sides or the tires will rub the bed sides. I got a '79 Camaro rear axle in my '49 Chevy 1/2 ton. I tubbed the bed with "Mini" tubs for the added tire clearance. The tubs are 1 1/2" , so now I have 2" clearance from inside of tire to bed side. Ford used a set up like this from the factory or late '40's early '50's 1 ton pick up beds. I use no rear sway bar because it made the ride to stiff. | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | When I put my 55 together,I had to use wheels with a lot of backspacing,in order to get clearance between the tire and the fender.I would think that one inch should be sufficient spacing,especially if you are gonna drive it sensibly.If you are not comfortable with the one inch you could also think about a narrower tire.So either wheels with less backspacing or skinnier tires. | | | | | Joined: Jan 2008 Posts: 227 Shop Shark | | Shop Shark Joined: Jan 2008 Posts: 227 | I would have to recommend fitting the Panhard bar with that much clearance.
In this country, all parallel 4 link rears have to run a Watts linkage/Panhard rod for engineering and registration.
Will not stop tyre scrub over severely uneven ground, but will control lateral movement of the diff assembly through cornering on the road. | | |
