9 members (warlock, mick53, 55shaker, fonz8261, Ponchogl, RoadsScholar, Gdads51, Otto Skorzeny, 32Fordpuchoptop),
105
Mod | | | Forums66 Topics128,048 Posts1,055,626 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 30 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 30 | My buddy has a '35 Chevy tow truck he is trying to register but we can't find the ID number. Can anyone tell us where to look? | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Check on the floor, passenger side by the battery box hole. There was originally a small metal tag with the VIN on it. Unfortunately, most are gone or damaged to the point they can't be read.
Bruce | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | That would be the engine number on the title wouldn't it? There is a difference in opinion as to whether the serial number on the data plate Bruce refers to or the engine number is the "VIN". For my money it's the number on the title which through '55 was normally the engine number. Your engine number should be on a raised boss by the distributor. I don't recall when the change was made from the front to the back so your engine number would be just in front of or just behind the distributor on the block (on my 38 it's just behind the dizzy). If I'm full of beans someone will point that out.
| | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | If your friend has an old title or registration for this truck, try to match that VIN# to the stamped number on the motor. If the motor has been changed or paperwork lost the DMV or CHP will assign a new number and attach a new id plate. I was able to find a service that does DMV legwork for car lots and this person did my registration for a reasonable fee. Best of luck
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I've owned four '36 Chevrolet's. The tag by the battery is the VIN number. Every one I owned had that VIN on the title. Possibly some states did it differant but not the ones I've had.
Bruce | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Not all states were the same. Apparently South Dakota used the serial number on the data plate if that's been your experience. I've been advised by Gene Schneider (sp?) over at the VCCA and others that most states, including my own, used the engine number through '55. I've certainly not registered pre '56 vehicles in every state so if they're all wrong so am I. At any rate those asking where their "VIN" is should get all of the info that applies. I was just trying to make sure the initial poster was aware that not all "VINs" were on a metal tag.
