4 members (Woodcmiami, Sjm, Steelonsteel, Hotrod Lincoln), 122 guests, and 6 robots.
Topics128,266
Posts1,058,385
Members48,485
#529313 04/17/2009 4:21 AM
My buddy has a '35 Chevy tow truck he is trying to register but we can't find the ID number. Can anyone tell us where to look?
Check on the floor, passenger side by the battery box hole. There was originally a small metal tag with the VIN on it. Unfortunately, most are gone or damaged to the point they can't be read.
Bruce
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
That would be the engine number on the title wouldn't it? There is a difference in opinion as to whether the serial number on the data plate Bruce refers to or the engine number is the "VIN". For my money it's the number on the title which through '55 was normally the engine number. Your engine number should be on a raised boss by the distributor. I don't recall when the change was made from the front to the back so your engine number would be just in front of or just behind the distributor on the block (on my 38 it's just behind the dizzy). If I'm full of beans someone will point that out. grin
Tiny #529412 04/17/2009 3:09 PM
If your friend has an old title or registration for this truck, try to match that VIN# to the stamped number on the motor. If the motor has been changed or paperwork lost the DMV or CHP will assign a new number and attach a new id plate. I was able to find a service that does DMV legwork for car lots and this person did my registration for a reasonable fee.
Best of luck
1946 1/2-Ton Chevy
Tiny #529450 04/17/2009 6:39 PM
I've owned four '36 Chevrolet's. The tag by the battery is the VIN number. Every one I owned had that VIN on the title. Possibly some states did it differant but not the ones I've had.
Bruce
My Trucks
Stuff I Collect
Ex Hall Monitor
Ex Hall Monitor
Not all states were the same. Apparently South Dakota used the serial number on the data plate if that's been your experience. I've been advised by Gene Schneider (sp?) over at the VCCA and others that most states, including my own, used the engine number through '55. I've certainly not registered pre '56 vehicles in every state so if they're all wrong so am I. At any rate those asking where their "VIN" is should get all of the info that applies. I was just trying to make sure the initial poster was aware that not all "VINs" were on a metal tag.
