1 members (baldeagle),
117
Mod | | | Forums66 Topics128,274 Posts1,058,432 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2008 Posts: 130 'Bolter | | 'Bolter Joined: Sep 2008 Posts: 130 | These T5's,What years and what trucks can i find them in? I'm using a tail shift model now. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The best one for putting these old trucks are the mid 80's S-10 pickup ones. The 88 up went to an electronic speedo so is not good unless you have custom gauges w/elec. speedo or a expensive adapter. The S-10 used it up into the mid 90's. The Camero version is stouter but the shifter is way back at the rear so must be used with bucket seats. They were used in Mustangs, Jeeps, & Mazdas & others but each has its own specifications. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | you can put the s10 tail housing on the camaro to move the shifterup ron | | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | I am using a T-5 from what I think was an 89 S-10. Does anybody have a source for a shifter? I would like something with a longer handle and that means a shorter shift. I have seen the article on Stovebolt on how to modify one. Also, B&M used to make 2 different model numbers, but they don't seem to be produced anymore. I was wondering if a Camaro or mustang shifter would fit and could be modified with a longer handle? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Todd,
use the stock shifter, fabricate the handle, and if you need , shorten the throw per the article. The Camaro and S-10 use the same shifter, the ford can be used, however it needs to be modified to fit the GM tail shaft.
PM or email me for specifics
Scott
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | The correct B & M number for the S-10 is #45049. I would check eBay for one.
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2009 Posts: 192 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 192 | That's what I did and it's great.But I need to add the crossmember,will the one classic parts work ? Thanks | | | | | Joined: Jul 2005 Posts: 2,031 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 2,031 | there is TONS of info on this site as well as inliners http://www.inliners.org/do a search
Jim & Caroline The highway is for gamblers, better use your good sense." Gooday-that's my 1¢ answer due to the lousy economy ~ cause I ain't got - no . mo . doe Every Shaver | Now Can Snore | Six More Minutes | Than Before ... | Half A Pound for Half a Dollar | Spread On Thin | Above the Collar || BURMA-SHAVE
| | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Check the June issue of Street Rodder. The Professor Hammer section has a picture and description of a remote shifter modification for a T-5.
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: May 2006 Posts: 166 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 166 | Thanks, for the B&M part number. I seem to remember that they had a second part number for a shifter with an even shorther throw, but I could not find it on ebay at all. If they made a second type, it must have sold out all excess inventory.
So, a Camaro shifter would work if I modified the handle as well? | | |
