| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2008 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2008 Posts: 47 | Hi all,
I have a 1958 6400 2-ton Chevy and for a variety of reasons I am wanting to take the flatbed off and the 2 outside duals and drive it on the road like that for a while. Can this be done safely and without causing harm to the truck?
thanks and have a good day,
Harrydale in SE MO. | | | | | Joined: Jul 2006 Posts: 584 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 584 | I don't see why not. Make sure the rears are snug since you'll loose some of the thickness which the lugs tighten against. Also, because the threads where the outer wheels were might be buggered a little. Check local laws for flaps and lighting. | | | | | Joined: Nov 2000 Posts: 1,966 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,966 | where in SEMO, if I may ask? I'm a native of the Mississippi County town of Wyatt - Missouri's eastern most city!!
Professional Novice
