2 members (ShopRag, GradyB), 116 guests, and 1 robot.
Topics128,035
Posts1,055,564
#528265 04/14/2009 6:14 AM
V
Apprentice
Apprentice
V Offline
Any ideas to insulate the enclosed portion at the rear of a cab? I want to super insulate my cab and have done all exposed areas, but the only access to the upper rear of the cab is through the dome light and small holes at the rear of the headliner. Stuff with fiberglass pink, spray foam...??
You might try the spray foam, but remember it expands and could put a lot of pressure on the sheet metal causing it to distort.
GM uses a lot of foam for insulation in their roof pillars and rocker panels.I know cause I nearly burned up a Cadillac welding on a quarter panel, the stuff took off like a dry Christmas tree!!
For the exposed areas under the headliner, there a lot of insulating products available.
Check with your auto body supplier, they have foam fillers from 3M and others that don't expand as agressively as the building foam.
If you spray foam it, I would use a closed cell foam. Moisture in an open cell foam will hold the moisture for a long time. I think I would just stuff some fiber glass in there. At least you could get it out later if need be.
Moderated by  ndkid275, Phak1
