0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#52808 11/24/2005 4:16 AM | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | i got a 283 in my 64 with 3 speed on tree its original as can be im wanting to totally rebuild new everything but i need a combination of parts some say use double hump heads some say 305 heads defantly a 4 bbl and nice cam nothing nasty just enough to possibly squeze out 300 horses ill be using original center dump manifolds with smithys glasspacks x pipe also but as far as what i actually need inside engine im lost as long as it will run on 93 octane im happy you guys help me out and let me know what all you may have or had in the past .. -------------------------------------------------------------------------------- | | |
#52809 11/24/2005 4:43 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | More than one horse per cube running on pump gas.
I'd clean up the valve covers, look for an early dual carb manifold, switch to a vintage dual point distributor and put those parts on a crate 383 stroker motor.
Should still pull 300 horse, and still look like a vintage motor to most people looking under the hood.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
#52810 11/24/2005 5:43 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Myself, I would run the camel hump heads & a slightly dished piston, have the seats replaced w/hardened. Gasket match everything. Use a cam around 290 adv. duration & around .450 lift. Good q-jet or 600 Holley on alum intake. Pay for balancing, get a good flywheel. HEI, double roller timing chain. Not positive you will get 300 honest HP to the rear tire(it is "only" a 283), but this combo has run very well for me on a couple Chevs in the past. I have also seen rodders bore 283 .120 or more for extra cubes. I have my eye on a 62 283 in a C50 nearby. My 2 cents, Brian | | |
#52811 11/24/2005 3:53 PM | Joined: Feb 2005 Posts: 112 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2005 Posts: 112 | hey thanks brian sounds like a good combo | | |
#52812 11/28/2005 12:07 AM | Joined: Nov 2005 Posts: 24 Junior Member | | Junior Member Joined: Nov 2005 Posts: 24 | Since you have a computer... why not call Summit racing and get a program called "Desktop Dyno" it will show you what horsepower theoretic pieces will make to a very close margin... usually within 10%... it will take the guess work out and allow you to make power with different head, cam, piston, carb combos.... and will allow you to maximize your performance dollar.... if you saw some heads on Ebay... this program would let you know what could be done with them in a matter of minutes... buddy have some forged flat tops he doesn't want???.. now you know what to do with them.... this program and shopping on Ebay or the Racepages make parts hunting and engine building fun... without the 'oops' of a poorly performing combo... money well spent...buena suerte amigo...make it smokin V8! -K | | |
#52813 12/01/2005 7:37 PM | Joined: Apr 2005 Posts: 1,971 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 1,971 | I'd spend the money on hotrodding a 350 or not spend so much money on the 283 and just make a dependable street motor out of what you have (cam, carb, exhaust, intake manifold). If you want HP, start with some cubes and the sky is the limit. | | |
