7 members (TUTS 59, niobrarafun, Nick in Manitou, lumbersawyer, SmalltownTRKGuy, 55shaker, Oldpickupman),
106
Mod | | | Forums66 Topics128,195 Posts1,057,378 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | I put in an RCI fuel cell w/sender in my '57 Suburban the other day. I grounded it, filled it with about 10 gallons of gas in the 20 gallon fue cell. When I hooked up the gas gauge to the sender it didn't work. I reversed the wires on the back of my gas gauge and it pegged it out to full. Any ideas on why it won't register the level? Thanks for any help, Bongo | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | if the sender came with the cell it'll be 60 ohm, the stock gauge needs a 30 ohm sender
Bill | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | my rci fuel cell sender is 0-90 ohm,but agree with red.................dave
1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | David, Did you change out the 0-90 ohm sender? Where would I get a 0-30 ohm sender? Can I put some kind of resistor or voltage regulator on it? Bongo | | | | | Joined: Jan 2008 Posts: 36 Apprentice | | Apprentice Joined: Jan 2008 Posts: 36 | Red, My cell came with a 0-90 ohm sender. Can I put a resistor or voltage regulator of some kind on it? Where can I get a 0-30 ohm sender if I can't "dumb" mine down? Bongo | | |
