1 members (Steelonsteel), 113 guests, and 3 robots.
Topics128,196
Posts1,057,391
Members48,471
Apprentice
Apprentice
I put in an RCI fuel cell w/sender in my '57 Suburban the other day. I grounded it, filled it with about 10 gallons of gas in the 20 gallon fue cell. When I hooked up the gas gauge to the sender it didn't work. I reversed the wires on the back of my gas gauge and it pegged it out to full. Any ideas on why it won't register the level? Thanks for any help, Bongo
if the sender came with the cell it'll be 60 ohm, the stock gauge needs a 30 ohm sender
my rci fuel cell sender is 0-90 ohm,but agree with red.................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
Apprentice
Apprentice
David, Did you change out the 0-90 ohm sender? Where would I get a 0-30 ohm sender? Can I put some kind of resistor or voltage regulator on it? Bongo
Apprentice
Apprentice
Red, My cell came with a 0-90 ohm sender. Can I put a resistor or voltage regulator of some kind on it? Where can I get a 0-30 ohm sender if I can't "dumb" mine down? Bongo
