0 members (), 120 guests, and 3 robots.
Topics128,093
Posts1,056,474
Members48,444
#508712 02/21/2009 11:18 PM
How many of you guys use a straight axle and hows the ride and what updates have you made. Trying to decide between mustang 2 and a dropped axle.
I'd say most of the folks with daily drivers here use the stock axle, not dropped, but there are some who've clipped with something ... if you want low, do whichever you can afford, the dropped axle will still drive like an old truck, the clip will feel more like a car ohwell
Mine's still straight axle, it rides about as can be expected. Mine does have the HD suspension option (3/4 ton springs) though.
Bill Burmeister
I am also stock, but 1950 1-ton. It rides like a wheelbarrow. I'm not sure those front springs have ever flexed. Hahaha. Thats what the big springs in the seat are for. It rides like a truck!
Christopher
1950 1-Ton
"Rochester"
In the DITY Gallery
1949 GMC Panel Truck
1926 Model TT Truck
I still have my straight axle, too. I rebuilt the whole thing last spring.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
Iv got a 4" drop axle on my panel, and a 3" drop on my suburban.
Former Workshop Owner
Neither of mine can be listed as drivers yet, but I plan on leaving the original axles under both my '41 and '59 half tons. I am hoping to have the '59 on the road in a couple months.
~ J Lucas
2006 GMC Envoy 4.2 I6
2023 Ram 2500/Cumins 6.7 I6
2002 Silverado 2500 Gas 6.0
1941 Chevy 1/2-Ton
1942 Chevy 1.5-Ton SWB
My Flicker Photos!
I
I Offline
Both my '60 and '65 have IFS stock. But My old work truck is a '64 Ferd 3/4 ton with a straight axle which I will leave alone. It drive's like a tank but I only use it for hauling wood or whatever. I wouldn't use it as a daily driver though.
Iron Clad
The panel has the straight axle under it and I plan to use it. The previous owner checked/replace the leafs and arch and also put new polyliners in between them. It also came with the sway bar so WHEN I do get it on the road I'm hoping it will work pretty nice.
Yes I use that ol straight axle myself in my 55 Cameo, wished though one of you guys would give me a part number on them there front spindle bushings.
"Spindle bushings"? Are you meaning the kingpin bushings? If so, the Moog number is 8444B. I beleive that kit does both sides.
Bill Burmeister
Using the old straight axe on my '47 Chevy rat, I think I gives the truck a great period correct ride, it takes u back to simpler times. That's the way I remember riding in it as a kid, ofcourse it was all original then. But if ur gonna have a truck, I say let it ride like one.
Mine still has the straight axle under it, it rides like a truck. Modern trucks ride like cars. I get bounced around a bit, but I expect that. I also hauled home a load of wet dirt last weekend, approximately 3000 pounds. I still had 1/2 my travel left in the rear suspension.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
