3 members (3800GUY, Hanks custodian, Bill Hanlon), 191 guests, and 5 robots.
Topics128,099
Posts1,056,168
Members48,436
#527052 04/11/2009 12:42 AM
Not sure where to ask this question....
I was just chatting up an old carb rebuilder and he showed me what appeared to be an old Clifford intake with integrated water heating set up for two Stromberg 97's. It had three posts for each carb..<
Anyone seen one of these? Would it do well on a 235 or a 261?
I measured the ports, about 1.5" and spaced to fit one of these motors.
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Was it a "log" style manifold or more like the Harper?
Hoyt
It was log style with only two carb mounts. Same carb mounting as those Harpers. BTW, That Harper set up is really cool!
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
I thought Cliford just made the 1 holley carb config.
Keith
It was old. Had been on the top shelf for some time....
It looked like the current holley intake except with two carb mounts instead of the one. They were spread to cover all three ports, of course.
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
I've seen several Edmunds, 3 bolt for dual Ford type carbs, water heated, for 216 ci Chevs.
1946 1/2-Ton Chevy
Could have been an Edwards. I forget the name on it. If it's good for a 216, would it be good on a street 235 with a couple of ford/holleys? Which ones?
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
There was an Edmunds manifold with two Ford carbs on ebay recently. Opener was $385 and there were no bids.
Hoyt
That looks like it, thanks Hoyt and JiMerit. Those carbs look mismatched in Hoyt's pic.
I'd like to know if this would be a good setup for the street. Any ideas?
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
Wow, reserve not met.... on ebay
'58 Task Force
'59 MGA
'97 F150
'06 9-2x
