1 members (1 invisible),
105
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've been thinking a lot about making precise measurements as I make modifications on my 1-ton frame. Recently my brother showed me a $600 piece of bar stock that had a number of threaded holes in it. The holes are for mounting a caliper to the bar, to make the bar part of a long precise measuring tool.
So after looking at that I was thinking I could make something using the same idea but based on stuff I have laying around.
I have some 10 foot sticks of conduit leftover from a project a few years ago. So I was thinking I'd contrive a way to attach a caliper to one end, and drill a hole on the other to allow mounting a pin to measure from. As long as the caliper is mounted in a way that is stable, and the distance from the stationary point to the drilled hole is known, I should then be able to make accurate measurements of about ten feet without the problems associated with holding both ends of a tape measure and then reading it accurately.
Drilling more holes allows shortening the measurements. Splicing two pieces of conduit would allow extending the reach up to 20 feet.
Since most of my measuring points are holes drilled in the frame, I can use the lathe to turn rod to exactly fit those holes, and either turn some of the rod small enough to fit in the hole drilled in the end of the conduit, or drill a hole in the one piece of rod (on the lathe to ensure its centered) and drop a smaller rod to match the hole in the conduit into.
Does my description make sense? Is there a better way for a guy working alone to make precise measurements up to 20 feet? Is there a commercial product that does the same thing and doesn't cost more than a cheap caliper, a couple sticks of conduit and a little hardware?
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Sep 2006 Posts: 841 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 841 | i'm not that familuar with what you are replicating, but will the conduit be rigid enough? | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Good question. Since much of what I'm measuring is actually comparing one distance to another my first thought is that any flex will cancel out. But in cases where an actual measurement is required that flex would be a problem.
The piece my brother had appeared very rigid.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | What if you used something like a very small cable instead? I think any type of small string, twine, etc., may stretch. You could put a small precision crimp piece on one end with a nut to keep it adjustable. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Hmm. A cable of a known length with a loop of some sort on one end, and a caliper fixed to the other. That might work.
The downside is it would need to be pulled tight to overcome the pull of gravity on the middle of the cable.
That is probably the advantage of the conduit over cable, in that it would sag less.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Steve,
I'm not sure you need accuracy more than a standard tape measure would offer. Pulling a tape off of holes, rivets or 'like same' frame locations seems like it would be more than accurate.
Stuart | | | | | Joined: Feb 2006 Posts: 1,867 Shop Shark | | Shop Shark Joined: Feb 2006 Posts: 1,867 | I was thinking a cable might be better because it would be easier to pull taut, instead of trying to support the sag of the conduit.  I also havent done any precise measurements yet... | | | | | Joined: Apr 2004 Posts: 888 'Bolter | | 'Bolter Joined: Apr 2004 Posts: 888 | What if you mounted your measuring device to a piece of threaded black pipe? You could change to shorter/longer pieces of pipe. Could need some extra hands if you went real long.....I haven't done many precise measurements but have used a "story pole" in construction. Dan | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Well Jeff I clamped a stick of conduit horizontal and checked it for sag. It sags...
I also played with my 24 inch caliper and the ten foot stick of conduit and I think I'm going to go that route. The sag will be consistent and most the measurements I'm going to care about its more important both sides be the same than that I hit any particular measurement.
Black pipe might be stiffer, but it would be much heavier and I'd have to buy it while I already have about 40 foot of conduit just leaning against the wall in my shop...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Why not devide this task in two? I used a shorter measuring stick made of stable 3/4" strip of plywood, that could reach the 1/2 way mark of the frame. 1 for the front section to center area and 1 for the rear of the frame to center. Drill out all necessary hole locations in the stick. Then I compared left to right holes by just flipping the plywood measuring stick left to right on each side. Repeated this on the opposite end of the frame. Fairly accurate and no sag in measurements. Hope this can help. | | | | | Joined: Nov 2006 Posts: 324 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 324 | Forgot to mention. On 1 side Clamp the plywood to the frame and drill out from the back, this should give a pretty accurate hole registration & location. | | |
