3 members (UtahYork, Millenimech, klhansen), 168 guests, and 1 robot.
Topics128,115
Posts1,056,289
Members48,439
#526678 04/09/2009 10:56 PM
1 Offline
Sorry if this should be in another section, i didnt know what to put it in.
Driving last night, went to my buddies house, i had about 3/4 of a tank, got out went in and partied for a while, got back in the truck and gas gauge went haywire. I cranked it and the dial went past the full marker about 1/4 inch to the right. Even when its full it only goes to F, never past it. It seems to me like its stuck or something, because usually when i go up a hill or hit a bump the dial swings back and forth like a clock, but now it doesnt move AT ALL, not even a little swing.
Any ideas, i know nothing about this area. Thanks in advance,
Preston
3 Speed Or No Speed
1965 Chevrolet C10 Stepside
I would look at the sending unit in the gas tank and see if it's dirty. You can replace it also, I don't think their very expensive. Check the wiring too going to the sending unit, you might have a bad connection.
Joe
54 Triumph TR2(rhd)needs total resto.
60 Apache 10 stepside shortbed
99 Excelsior Henderson
cal55 #526685 04/09/2009 11:26 PM
I agree with cal55. Check the sending unit, and connections. Make sure the sending unit and the gauge are the same ohm rating. I spent a lot of money learning this lesson. Guages and sending units do go bad, so you need to look at each one to see the guilty party.
1 Offline
Could either of you tell me what the sending unit looks like and where its located, i have the regular 18.5 gallon tank behind the seat
3 Speed Or No Speed
The sender is the only thing on top of the tank behind your seat. Unhook the wire and see if the gauge reacts. I doubt that it will. If the gauge does still peg when you turn the key on it's not the sender. I think you have a short in your harness under the kick plate some where, been there done that,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
1 Offline
"I think you have a short in your harness under the kick plate some where"
This, i'm guessing means i have a short in one of the wires behind the instrument panel? Oh i remember what i did yesterday. i plugged my phone charger into my cigarette lighter and charged my phone, could that have done anything?
3 Speed Or No Speed
