9 members (Gdads51, RdsLessTaken, Otto Skorzeny, Steelonsteel, Wayne67vert, cmayna, klhansen, 55shaker, Stewart2),
128
Mod | | | Forums66 Topics128,165 Posts1,057,010 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 29 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2006 Posts: 29 | I suppose this has been asked before. I did a search and came up empty.
Can AD truck rear fenders be cut down to fit on AD Panel/'Burbs?
Sure looks like a good metal person could pull it off to me... | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | No - the AD pick up truck fenders have more outward bow to them. The panel and 'burb fenders are flatter outer face. I already trying it , and the fenders didn't look right on the panel/burb. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | I've seen it done successfully. But the purpose was not to 'replace' the stock fender, but rather to fit the opening and cover a tire put further outside the side of the truck. Here is a picture. And more pictures. Start around 100_0486 and poke around... I took a bunch of pictures of this one.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: Apr 2005 Posts: 381 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 381 | You are right OldSub. If you got a modern rear axle that is too wide, then the cut down pick up fenders will work at covering up the tires. This would be most likely used in a street rod situation. Or - If you were staying stock but wanted to put a dually rear axle in it, that would be a wild set up. | | |
