5 members (Hanks custodian, KEVINSKI, Southerntruck, Gray_Ghost, Hotrod Lincoln), 148 guests, and 1 robot.
Topics128,162
Posts1,056,932
Members48,458
#526225 04/08/2009 7:23 PM
I suppose this has been asked before. I did a search and came up empty.
Can AD truck rear fenders be cut down to fit on AD Panel/'Burbs?
Sure looks like a good metal person could pull it off to me...
No - the AD pick up truck fenders have more outward bow to them. The panel and 'burb fenders are flatter outer face. I already trying it , and the fenders didn't look right on the panel/burb.
I've seen it done successfully. But the purpose was not to 'replace' the stock fender, but rather to fit the opening and cover a tire put further outside the side of the truck.
Here is a picture.
And more pictures. Start around 100_0486 and poke around... I took a bunch of pictures of this one.
You are right OldSub. If you got a modern rear axle that is too wide, then the cut down pick up fenders will work at covering up the tires. This would be most likely used in a street rod situation. Or - If you were staying stock but wanted to put a dually rear axle in it, that would be a wild set up.
