5 members (1955 1 Series, Southerntruck, tclederman, Rusted Nut, Peggy M), 38 guests, and 8 robots.
Topics128,010
Posts1,055,308
Members48,419
#526487 04/09/2009 6:32 AM
I installed the flywheel on my 235 and then I read the Shop Manual (note to self: do this in the opposite order next time). The Shop Manual says to apply Goodyear Pliabond #3 between the flywheel and the crankshaft. I didn't do it. Would you advise me to remove the flywheel and do it over, or ignore the recommendation for Pliabond? If I do it over, is there a modern equivalent to Pliabond #3? What does this stuff do, anyway?
norcal49er #526490 04/09/2009 6:45 AM
What the heck is that? ohwell
Sounds like something to help keep the two together. If your concerned put some loctite on the bolt threads. I just torque them down with the proper lock washers and havent had a problem.
Jeff
My 1953 Chevrolet
1947.1 Gallery
