1 members (Hotrod Lincoln), 74 guests, and 2 robots.
Topics128,135
Posts1,056,423
Members48,441
#525518 04/07/2009 12:26 AM
Looking to install the side motor mounts on the 350 small block i have in my 52. Where can i find a set? The LMC catalog only shows the small block mounts for a 54-59 and nobody their knows what they are talking about!!!! will they work or does anyone have a suggestion......
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I've used something like THIS & they are cheap to buy..Joe
American Classic has the same thing, all the vendors do, it's a universal crossmember that the side mount bolts to, only way to put a V8 in an earlier truck, any year
Jacks1952: you may want to look at my photobucket pics to see how I put my engine in. I didn't want to use the crossmember.
I got mine from JimCarter during a trip up there and with stovebolt discount and no shipping I did alright on them!
The chassis mounts are actually from Chassis Engineering.
Just another option to explore. When I bought mine a year ago they were $85 but not sure now. Most stuff has went up!
i got mine from chassis engineering also.not the cheapest way but a bolt in no brainer with good directions.they also have a bolt in trans mount that uses the original bolt holes.dont get much simpler than that.....................dave
1949 Chevrolet 3100
"When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
David is right on both accounts. If you measure and put the side mounts "dead on" the rear cross member will be "dead on".
I also used there rear cross member and it bolts right in the same place as the old one. No adjustable ends to mess with!
It makes a "tidy" set up.
How much did they run?
i just ordered and recieved today mounts for my 39 the kit was a univeral one "not a crossmember type" but its a trim to fit bolt in one the whole thing only ran me 60.00 got it from a companty named Chassis Engineering Inc. very happy with the looks of it and the installation "still have that to go but looks fairly easy and your bay isn't cluttered with crossmenbers you don't need
here is their site link / www.chassisengineeringinc.com
1937 1/2 ton
Jacks1952: I bought my side motor mounts little over a year ago. At that time they were $85 minus my Stovebolt discount at JCarters. The rear crossmember I traded out with a fellow bolter but I see them in several places from $49 to $69. Shop around!
