2 members (cmayna, CuzzFuzz), 60 guests, and 7 robots.
Topics128,012
Posts1,055,320
Members48,419
#525283 04/06/2009 3:55 PM
How long is the OD cable? I bought on years ago off of eBay and believe it was from an impala or whatever the car of the day was.
I think it is a little short but do not know.
Is there another cable that is available for this purpose?
Oh. This is for my 55 2nd TF. Thanks
TIA
Dennis
oldbluetruck #525291 04/06/2009 4:07 PM
If you are looking for one with the "Overdrive" inscription on the handle you may be in for a long hunt. If you are just looking for a T-handle, try a local truck parts supply house. That's where I got mine--it's a T-handle that you can also turn to lock in place.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
56picup #525329 04/06/2009 5:57 PM
Thank you for the reply.
Is a truck parts supply house for the big rigs or just the off roaders/custom truck stuff stores?
Dennis
oldbluetruck #525347 04/06/2009 6:19 PM
If you are looking for a T-Handle with overdrive inscription, Ford had overdrive on their T-handles and they should be long enough. If you just want a cable, a PTO cable is available at parts houses in rural areas and dealers parts houses that sell larger truck parts.
crenwelge #525351 04/06/2009 6:27 PM
Really. I want a cable that will work. I don't care if it has the overdrive inscription.
I would like it to be long enough to attach to the bottom of the dash and reach the transmission, have the T-handle, and be heavy enough to do the job.
The cables I see at he FLAPS are thin and I am concerned if they will do the job. Maybe, a hood unlock cable would work. I didn't think about that. Anybody used a hood cable?
Dennis
oldbluetruck #525402 04/06/2009 7:57 PM
Go to a driveline shop in Dallas area, probably several of them. They can usually make any type of cable from scratch.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
53moneypit #525412 04/06/2009 8:13 PM
Find a parts strore that handles Chelsea PTOs. A control cable for a PTO works perfectly. It will be long, so you can cut it to size. I've found that pretty much all of the cables normally available from the flaps are too flimsy and tend to bind up. Look to spend about $40 for a PTO cable, but they are well worth the cost to have trouble free operation.
Bill Burmeister
LONGBOX55 #525488 04/06/2009 10:56 PM
No more Chelsea brand. It is now Parker, i.e., Parker Hydraulics. Driveline shops and mobile power distributors are usually the same outfits.
Dave
53moneypit #525491 04/06/2009 10:59 PM
Was that a recent change? The cable I got for mine was in a Chelsea box.
Bill Burmeister
LONGBOX55 #525564 04/07/2009 2:13 AM
I just measured mine with the overdrive inscription, from the end of the T handle to the end of the housing is 42" long. It worked fine on my 1966 El Camino.
chevman32 #525735 04/07/2009 3:04 PM
Thank you for all the information.
The beauty of this is to receive information from all over. The bad thing is not having someone in Dallas say go here and get this. Or 'I have one - here you go.' I have no idea what a 'hydraulics, driveline shop, or mobile distributor' is. Or Chelsea vs Parker.
Sorry. I am simple in that way.
I will look for the 'heavy duty' PTO t-handle cable that is 42 inches long.
Thanks again to all for your help
Dennis
oldbluetruck #525909 04/08/2009 12:30 AM
Dennis, for a big rig parts store, try FleetPride, the concrete company that I work for gets the majority of the mixer truck parts from there. Here is where one is the Dallas area: right here.
66stepside #525924 04/08/2009 1:17 AM
Dennis,
I got mine from Concours Parts in Carson City, Nevada.
They are the Ford side of Golden State Pickup Parts.
Part # A9AZ-7A650-A, $50
http://www.concoursparts.com/
It's a universal trim-to-fit cable.
You can also get it from Dennis Carpenter.
same part #
http://www.dennis-carpenter.com/
They will be in town for the Pate swap meet.
You might be able to get them to bring you one and save shipping.
regards,
Leon
Leon #526145 04/08/2009 2:37 PM
Thanks Leon. That is exactly the information that I needed.
I am not sure if I will make it to the Pate but can order it from Concours Parts.
Thanks Again.
Dennis
