8 members (GRNHydra, David Bush, JW51, Oswald, Otto Skorzeny, Wally / Montana, Guitplayer, NJC),
104
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,060 Posts1,055,838 Members48,427 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 145 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2008 Posts: 145 | I have a 62 235 engine. I put the clifford intake and headers on with a holley 390. I am going to replace the jets and discharge nozzles on the carb as recommended by clifford. So I'm going to run the exhaust. I originally thought that the more flow the better? So I got the collectors for the headers at 2 1/2". Then a friend told me that too much flow can rob you in torque. I never heard that before. But should I reduce the duel exhaust to 2"? I plan on putting in a X pipe also. In the Gallery[yrl=http://viewmorepics.myspace.com/index.cfm?fuseaction=user.viewPicture&friendID=43825635&albumId=1717519]More pictures in MySpace[/url]
| | | | | Joined: Feb 2000 Posts: 5,205 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,205 | Six cylinder engines really don't respond like a V8 does when X pipes are installed, a simple H pipe will do the same if you want to save some money. As far as pipe size goes, keep it small since you are running two of them. Your engine will not produce any more exhaust then a stock engine does as long as you drive it like a stock truck. Higher rpm is the only way to make more exhaust, the intake and headers will only let air in and out easer, not produce more.
With that said, 2 2" pipes will be plenty, smaller pipe will hold heat in which lets the exhaust flow faster, it slows as it cools.
Joe | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I agree. 2" is all you need. Any more is bulky & unnessesary. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2003 Posts: 1,554 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 1,554 | Seems to me like 1 1/2 or 1 3/4 would be plenty for a 235.I am running 2 1/4 on a built 350,and most guys are running 2 1/2 on big blocks with good results.Just my 2 cts. | | | | | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | Take a look-see at my exhaust on MariAnne, my wife's 53' 3100. I made the collector and used a single in/two out muffler. Plenty of back pressure (what your friend was referring to) with a nice mellow sound. All pipes are std size for the model. | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Dave,
If you want a single tail pipe, Dave (53moneypit) has one of the best solutions. If not, all you need is a simple H-pipe to run duals. The cross over need not be much larger than 1.5". X-pipe would be a waste here as the velocity of the exhaust is not there. I would also run 1 3/4" to the mufflers and 2" the rest of the way.
If you have the motor spinning to 5-6 grand, then I would worry about running a larger exhaust than that
| | | | | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | Davidn, Scott and other have it right. Nothing larger than 1+3/4 or 1+5/8" is max if you are looking for gas mileage. Add H-pipe if you want smooth sound. Individual pipes if you want the rap sound. Move mufflers back as far as you can to move the sound back. Mufflers are your call. Many like glass packs, go for stainless pipes and mufflers to do it once. good luck
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
