3 members (Gdads51, Ponchogl, 2-Ton), 126 guests, and 3 robots.
Topics128,128
Posts1,056,670
Members48,450
OK, here's the deal...I have this problem every 8-9 months or so with my Rochester carb (a "C" is stamped next to it, GM stamped to the side of it; I only hear about Rochester B's...)--I'll be riding along, everything running fine, and the engine will spit, sputter and stop. I have to take off the carb, blow out all of the holes, jets, et al., with compressed air, then all is fine.
I replaced the gas tank a couple of months back, thinking there was crud in the old one, installed a filter just outside of the tank, then another just before the carb, but the same thing happened today.
It's to the point where I'm not confident enough to drive it too often or far, lest I have to get towed back or dismantle the carb, then take a can of compressed air for cleaning computer keyboards to the openings and apertures, then re-install (a pain in decent clothing and/or on a hot day).
My question: does anybody else have this problem with such frequency? I have filters on the gas line, I don't use any teflon tape (or the like) that might flake off and cause a carb blockage. Are Rochester's known to have this problem? I can't believe a carb (especially when these trucks were originally used on farms) could be that sensitive; it's ridiculous. I know nothing significant in size is getting into the carb and clogging up the works. I'm at a loss.
Any thoughts, suggestions? Thanks.
...oh, and it's a '50 3100.
My 52 did the same thing years ago when I got it. Thinking it was the carb, I had it rebuilt. Did the same thing. Had it rebuilt again: and again the same thing. Figured the carb was worn out so I bought a reman. one at the parts store. Did the same thing. Took it to an old mechanic that new about these vintage trucks. Found out that the fuel pump was bad. Replaced the fuel pump and the problem was solved. I don't know if this is what is wrong with yours but you may give it a try.
John Kinser
...but when I blow out the carb with compressed air, everything's fine. That wouldn't fix the problem if it was the fuel pump, which I replaced about 2 years ago.
V
V Offline
Mine just leaks every where but it runs fine.
grin Aint that the truth!
My 1953 Chevrolet
1947.1 Gallery
It was a bad rotor in distributor
How did you figure THAT out?!
eek
-Michael
Please type slow, as I can't read very fast.
1939 Chevy/Central Fire Engine
1941 Chevy/American Fire Engine
1950 Chevy/American Fire Engine
More Photos in Me Gallery
