6 members (Otto Skorzeny, R&S 51 GMC, KEVINSKI, Bill Hanlon, Swami29, Phak1), 100 guests, and 0 robots.
Topics128,125
Posts1,056,339
Members48,440
#524512 04/04/2009 4:21 AM
I thought I took more than enough pics/etc when we took things apart, but here we are scratching our heads... Got the motor back from the engine shop, and there are two small holes in front of and below the breather that we can't figure out. They go all the way through and aren't threaded.
Posted a picture with them circled in red here - help?
'56 chevy 235 engine
1956 Chevy 3600 NAPCO 4x4
1955 Second Series Chevy Short Box
1956 Chevy 3100 Short Box
Story in the Gallery
More pix and info on my web site
It's dark out, so I'm not going outside to check my engine, but I bet that upper hole is for a dsitributor hold down. If nobody else answers I'll check mine tommorow.
Devin
If you can't hose it out it ain't a truck
55 3100
63 Corvair Monza
64 El Camino
72 240Z
01 Suburban
That is the road draft tube hole (the distributor hole is over to the left). My engines have round head machine screws in those holes. I think those screws hold some baffles or other pieces of sheet metal inside the block (it's been a while since I have been inside a block).
Yep. That's correct. A rectangular-shaped, sheet-metal baffle plate is mounted inside the block through these holes. I just installed mine last week. Page 8-29 of my '58 Shop Manual says "Check to see that the crankcase ventilator baffle (attached to the block at crankcase breather hole) is not damaged and is securely bolted in place. Turn the crankshaft to see that the camshaft lobes clear the baffle".
To install the baffle, you will need to remove the oil pan and flip the engine over. The baffle slides between the cam shaft and the block.
norcal49er has it. Its a metal baffle to keep oil from blowing out the road draft tube.
Ouch. Thanks guys. Not sure what I'm going to do first - pull the engine and drop the oilpan, or head up to the machine shop that I left a couple grand at a week ago to do this job and knock the owner in the head...
Thanks for the replies. "Two steps forward, one step back" - seems to be a theme with these restorations (at least for rookies like me).
I think the pan will come off without pulling the engine.
David Colter
pics * 1954 wrecker * [color:#009900]1948 Chevy 1-Ton[/color]
V
V Offline
Remove the tie rod from one side and the pan will come out with the engine in place, unless there's something different about NAPCOs that would be in the way.
1959 3200 Apache Fleetside
In the Legacy Gallery
Sounds good - I'll take a look before I back the cab off and get the cherry picker out.
I'm not sure the engine guy is going to "find" this baffle (I found pictures before the tear-down, it was definitely there when I dropped it off because I can see the heads of the screws you guys are talking about). I just left him a message. Ugh.
